Aygo, C1, 108 high level brake light lens removal
31 Mar 2020
Fareham, Hants
Any tips on removing the high level brake light lens from a Peugeot 108?
Its the same as the mk2 C1 and Aygo.
I have managed to crack the lens on my granddaughter's car whilst trying to get her rear wash wipe working. :(
Mk1 has 2 screws up to 2014, the mk2 from 2015 onwards is held in by clips that cant be seen.
Have you tried careful levering with a plastic spatula or similar? If there isn't any trim behind the lamp unit for access that must be the way it fixes?
John :)
Piece of trim that can be removed say 2 x 4 inches but you cant see to get hold of the spring clips that hold the cluster in place.
Does the trim cover the electrical connection?
Maybe a good squirt of silicone spray around the clip area may prevent damage as you lever away......I have replaced a C1 lamp but not the later Aygo.
John :)
Thanks, managed to get the old one out, it was knackered anyway. The new one will just push in against the pressure of the spring clips. I have had a good look and now waiting for the replacement to arrive.
