[b]PLEASE HELP ME WITH BURST PLASTIC WATER LINE[/b]
21 Feb 2005
Hi
I live on a large piece of property and I am having many problems with my water line. I get my water from a large creek that runs through my backyard. THe plastic water pipe that is in the creek burst and is squirting water straight up in the air. THe crack is located 1/2 way between the submersable pump and the pump house (which has my compressor tank). What would be the easiest simplest way for me to fix this problem, ASAP. I shut off the pump breaker so it wouldnt keep the pump going constently, but now I am worried about if it freezes then Im screwed even more. My spouse is out of town working, and in the last year I have done lots of things myself. So with instruction I am capable of doing this Myself....please help me someone.....
Niki
:cry: :eek: :cry:
__________________________
Moderator
Please see 5 & 6a
...but then you mentioned that you had a spouse. :(
Go to your local plumbers merchants and purchase a plastic coupler to fit your pipe. Turn off supply and drain. Cut the split out and join with coupler.
Hope this helps but without seeing the job............ :D
