I am having a water pump installed near my water tank (3.5 bar twin) and I want to know if I have to run a separate line from my fuse box or can I get away with a spur.. BTW I will not be installing myself but I have had conflicting advice on what is needed.
It may be connected to an appropriately fused spur... Any circuit where the cable is less than 50mm below the surface of the plaster / floor or is not encased within earthed metal trunking MUST be protected by an RCD. Which zone in the bathroom do you intend to place the pump? This is a job for a Part P registerd sparks, not a DIYer
I am looking for it to be installed in Zone 2. I will check that it is protected by RCD. I have got someone to do it who is hopefully a registered sparks. Thank you for the advice, as you can see it is on my mind as I research at 2 am.
