I'm after some clarification on the replacing of a WC with a back to wall close coupled unit.
The new WC is flush all the way to the floor so you cannot access the soil pipe. How do you ensure that the connector between the soil pipe/toilet is fully engaged when fitting?
Also I can't see how an isolating valve can be fitted in the cistern feed as you would need to remove the toilet away from the wall to turn off the supply. Then you will seperate the waste pipe from the toilet etc etc
How are you supposed to fit these things??!!
