I attempted to remove and cap off a water pipe that fed a wash basin. Bought the compression fitting, turned the mains water off, started cutting and discovered that the pipe was iron or lead, not copper. The pipe is quite inaccessible, so I can't cut a thread onto it and cap it off, and the place where this particular pipe is joined to the main pipe is behind six inches of concrete in my cellar.
As a last desperate attempt, I tried to cap it off with the compression fitting (I wrapped the olive in teflon tape), which sort of worked (there just remained an extremely slow leak when I turned the water back on), to stop the leak I put some special mastic for fixing leaky pipes around the fitting, there's still a tiny leak, am going to try putting a bit more mastic on today.
Anyone got any suggestions about how I should have done it?
