Hi folks,
I have been researchimg this on the tinternet and the axcellent guid in the FAQ,s. However, I just want to check if I can balance my system in the same way. My system (which I will have completed tomorrow) has a T piece shortly after the boiler, the flow/return going left will feed the kitchen rad and 2 rads upstairs, the flow/return going right will feed the downstairs 4 rads. My question is, do I balance it as if it is 2 systems, i.e. start with the kitchen rad then the 2 upstairs, then balance the rads in order for the downstairs 4. Or is that over complicating things? Also, I am using barrier pipe, will the readouts on the thermometers be accurate if places on the barrier pipe tails?
Pippo
Pippo
