I've been playing about trying to balance our heating system and I'm now a bit confused about what to do.
If I've understood everything, when balancing rads with no TRVs, the return is left fully open and it's the flow side that is adjusted. If TRVs are installed they are normally installed on the return side of the rad and the lockshield on the flow is adjusted.
Our system has 2 way trvs and I was trying to establish which side was which so I opened all valves and turned the heating on to find which warmed up first. Turns out most of the trvs are fitted on the flow side, how would this affect balancing? 2 rads didn't heat at all, even with the flow to all others shut off and no air in them...
