banging boiler/pipes
19 Jun 2007
Durham
Baxi Bermuda W2. If I put the gas water heater on the tank rumbles & bubbles noisily to start, then when the :roll: water is hot the pipes or radiator upstairs (not sure which) clang as if being hit by a pan! Doesn't happen if I have hot water and heating on together! Confused!
Have you got gravity hot water or fully pumped? Sounds like gravity to me and you have a blockage. When pump kicks in for heating excess heat is taken out of boiler.
If you have fully pumped then possible zone valve on hot water fault.
Have read the definitions for gravity and fully pumped and have no idea!! Just a useless female see! :oops:
