Bar shower
4 Apr 2010
Humberside
If fixing a bar shower to the z bars that come out from a tiled wall with shrouds. Is it possible to put two washer in if not enough threads have been left after the shroud? Thanks
Depends what shape the shrouds are, I use a dremel when it comes to fine cutting like that.
Though I must be honest - I never use Z connectors, they are the worst things ever. Who fitted the feeds? Depending on what stage it's all aty, i'd be tempted to see if the fittings/feeds could be adjusted.
Could you get away with 2 washers, possibly, but never had to test the scenario TBH.
The preferred method is to throw away the offset connectors that get supplied with bar mixers and use a mounting kit such as
Presumably you are beyond that stage and need a work around an incorrect install. You could try 2 washers each side or cut down the shrouds.
Thanks yes I use the surface mounting kits. I haven't pulled the shrouds back yet. But I think will be z bars.
