Basin waste
15 Apr 2005
Yorkshire
Our basin wasnt draining so i took off the u bend. It was slightly gunked but not major. The blockage was in the basin waste itself. No way to rod it in situ (it was a click-clack with captive plug). I undid the plastic bolt holding the waste in and the bolt split. It had been fitted with silicone so I decided to go buy a new revolving plug waste. Fitted it after i scraped all the silicone out of the hole.
Disaster. The new waste is about 10mm shorter so the u bend dont quite reach it. The pipe goes straight down to the floor and has no adjustment in it, all the joints are solvent welded. Is the best solution going to be to cut the upstand pipe and insert a solvent coupler to extend it?
I got one of those from screwfix today. It was too long! So i sawed off the bottom of the adjustable bit, deburred it and it fits. But the waste leaks, so i took it out and siliconed the bottom of the waste up, before putting the washer and bolt back on tight. I smoothed off the silicone on the outside and stuck some on the threads too. Leaving that to dry for 24 hours before i out the trap on.
Why dont sink wastes come with some sort of rubbery soft gunky seal for the underside? Like a cistern donut. Just seems a flawed design
