The new bath has deck mounted valves that feed into a filling waste like this.
The filler has two inlets, one is blanked off off the other has an elbow joint.
The questions is: can I mix the outlet from the valves and just feed into the single feed on the filler or do I need to remove the blanking plate and feed in seperately? I'm guessing that mixing the feeds has the potential for water returning down one of the pipes and back through the valve?
Ta.
Ta.
