Bath panel for a 696mm bath in a 710mm space
6 Mar 2024
Hi all,
I'm trying to fit a 696mm bath into a 710mm space. I'm planning to silicone bath into place with wood frame underneath before tiling it on the 3 sides. which hopefully should sort out the gaps from above.
But I'm struggling to work out what to do about the 7mm gap at each end when viewed from the front. I'm considering buying a 800mm panel and trimming it down to 710, and make the best of it that way (see attached image), is that my best bet? This would leave the 7mm gaps either side of the bath itself above the panel height to fill, but just white silicone it?
Thanks in advance,
Russ
Had no idea bath panel end trims were a thing, sounds like just the job, thanks. :)
