drill - does it pop-out from under the bath lip or from the ends. These plakka panels can be held in place using a variety of methods, the most common being lifted into position under the bath lip at the top and held in position by screws along the bottom - if this is your type, undo the low screws, lift the panel to ensure the top edge is held under the lip, re-screw. Some panels are held by clips which engage with the support legs of the tub, just make sure that the clips (spring clips) have 'snapped' onto the legs. Lets us know if your panel is held another way.
