Bath spout without taps
4 Dec 2004
Wiltshire
I am fitting a new bath with shower. The bath has a single hole in the top edge to take a mixer tap. I have a very nice dual purpose shower valve unused in an earlier bathroom, designed to supply either the shower or the bath.
I would like to use this to supply a single spout for the bath (as well as the shower). Are there any such spouts without taps attached available? The bath it was originally supplied for filled from the overflow attachment.
TIA
Zillions. Olde curvy ones, modern thin slot ones - all sorts.
Didn't try very hard, did you.
GOOGLE - first query found dozens.
Knowing how intelligent, helpful and polite you all are on here, I came here first.
Cheers
After intensive searching, I've found one at £53, which is too tall anyway. Hardly zillions, or even dozens.
Cheers
are you psychic- or have you been lurking :wink: You should see the transatlantic feuds Tennessee v Scotland :lol:
Cheers
I missed that. However, have now managed to get a cheap(ish) overflow filler with pop-up waste for £63, which will fit the bill nicely as the bath is not predrilled for the tap/spout.
Thanks all for your help.
