Bath tap issue
18 Oct 2006
Buckinghamshire
We have bath taps witha shower outlet in the centre, recently it has been difficult to set the shower temperature with the cold tap. I seem to ahve to move it a long way and then the tempreature sudely changes a lot, small adjustments of the tap seem to make no difference until it has been moved about 1/4 turn and then there is a big temperature cahnge . .
ANy ideas?
I believe it isa Deva tap.
You've got no thermostatic control on a tap mixer, so it's likely that the tap jumper is sticking, and needs a clean and lubricate.
Lubricate the quick thread inside the tap with silicone grease, ideally.....give it a new washer too.
If the tap is of the cheaper contract types, a new insert could be better.
John :)
