Pls can any how help. I’ve spent a miserable day trying to fix my bath mixer tap. I have had this problem for a couple if weeks since we had a shower installed above the bath. ( see picture for which tap i have).Having read up lots , it seems water is leaking through the base of the hot tap and then down through the hole. In preparation to fix today i bought a fix a tap (essex) kit for acrylic baths
I took the bath mixer taps off today, ( (eventually- it took me a while as space is tight) ans washers were ok but i persisted and put on the new tap kit washer etc...
Outcome is still is the hot tap is still leaking from hot tap.
I’ve read posts to suggest putting silicone about base but confused as to where really
when we say base, is this when standing up looking at the bath and lifting up the taps and putting some sealant on where the tap hole is and then putting the taps through. Or is it underneath the bath directly around the hole and the. Securing rubber washer , brass plate and then brass back nut.
The fact i have changed the taps washers and still its leaking in the same place upon complete removal and installation of new seals - also new tap flexi connectors .. practically everything apart from a new tap, makes me wonder what the problem is.
Im suspicious that the rubber and backnut arent sealing because the bath is bumpy underneath. See pics
Or it could be the hot tap is faulty
last week i sealed around the taps with clear silicon on when the tap meets teh bath from above .. still leaked . I havent done it today/ yet but i a not sure it would make any difference. Any advice welcome ?
