I've just moved into a new flat and im having a problem with the bath taps - it's a spa bath and i've never had one before so i was fiddling, on top of the taps was what looked like a button/lever (similar to plug control) and so i pressed it - now no water will come out of the taps at all.
If i remove the nut from under the tap the water can come out there but pulling the lever up and down/twisting has no effect.
Pic can be found at www.lewty.org.uk/bath/tap.jpg
Any help is appriciated
