Bathroom Bonding Practicalities
4 May 2007
Just been looking at the nice diagram in the OSG that shows bonding in a bathroom. Question is in practice, in an existing installation, how do you discreetly run the cables say from a shower to a cold water pipe or from a shaver unit to a cold water pipe without ripping up floor/wall coverings?
I suppose if the shower had a pull cord switch and the water feed from the shower was from above then you could connect from the earth terminal of the switch to the water pipe in the loft space. But if the switch was a wall switch (outside the bathroom/zones) and the water feed came UP through the floorboards and was fed behind the bathroom tiles it would be more difficult.
Same problem with a shaver unit, if there isn't a convenient airing cupboard and there are no cold water pipes in the loft space would it mean channeling out the wall/tiles to get a cpc to the water pipes?
I'm sure there's a simple answer to this, problem is I don't know what it is..! Cheers
You only need to bond each circuit / service once, you do not need to bond every part of the circuit.
You can also use the pipe work as part of the bonding.
