Bathroom bonding question.
30 Aug 2005
Hi, we are renovating our bathroom and I have a quick couple of questions regarding bonding.....let me explain the scenario first...
First floor bathroom contains full size bath on one wall with an electric power shower next to a central heating radiator, toilet and sink on opposite wall, and finally bathroom light. We are busy replacing the floor and the equipotential bonding looked "odd". I understand the concept of equipotential bonding is to get all metal parts as close to the same potential as possible to avoid the risk of shock.
There are four bits of 6mm bonding wire as follows:
1) Sink hot and cold feeds bonded together under the sink, just under the taps.
2) Bath hot and cold feeds bonded together under bath, just under the taps.
3) Radiator feed bonded to bath hot water feed under bath, next to the bath tap bonding.
4) The power shower in the bath has its electrical supply coming down from the ceiling along with the cold water feed. An earth/bonding wire comes out of the top of the shower and is bonded to the copper pipe with a clamp.
I guess from an equipotential bonding perspective it's handy to have the central heating and hot/cold water pipework running under the bath - easy to get to!
All the water and heating pipework is copper, and soldered. The waste plumbing is plastic.
i) My first question is, does the equipotential bonding sound right?
ii) Another question, should there be a bond from the shower down to the bonding under the bath taps?
There is no cold water storage tank in the loft, our cold water supply comes in and connects directly to the taps and the boiler. I have had a good look in the loft, all the copper fittings are soldered. The cold water supply comes into the house and goes straight to the loft, where no doubt in the past there was a storage tank. The feed for the power shower is taken off main cold water pipe in the loft. The cold water pipe then goes down through the partition where it appears under the bath. I can only assume the soldered pipework is being used as part of the bonding.
iii) Final question, how is bonding tested? I can only assume this setup has.
Web searching has thrown up copious amounts of info. This appears to be the most confusing subject in domestic wiring. I understand the bonding doesnt have to be one piece of wire, and copper pipe can be used if it is soldered ( I take it only for the short lengths used in the bathroom).
Sorry for the long post. I have tried to find the answers myself, but I wanted to ask here first - before I push our already stretched budget and pay for someone to come in and tell me what I could have found out myself.
You don't say there is a connection to the lighting circuit, which is height / location dependant. Apart from this it doesn't sound wrong.
Providing the pipework runs direct from the shower to the bath in copper pipework there is no problem. You say you have a power shower run from the mains water supply????.... Do you mean an electric shower?
You don't say if you have a main equipotential bond run from the main earth terminal (MET) to where the water pipe enters the premises (within 600mm preferred).
Another point to note, working on electrics in a bathroom in England / Wales is notifiable under part P of the building regulations.
Hi Spark123, thank you for your reply.
The light is one of those low profile types mounted flush to the ceiling. The ceiling height is 3m and approx 1m horizontally from the edge of the bath. Out of the zones? There is no direct bonding connection between the light and the bathroom equipotential bonding.
Regarding the shower, yes I mean an electric shower. And yes, there is a healthy sized earthing conductor fitted right at the water pipe entry going back to the main electrical cupboard. I havent measured it, but it looks like 10mm. Should it be above or below the stop valve? It's above here. The main stop valve is right at floor level.
I just want to make sure about all this while we sort the flooring out, because now is the time. Yes, I read about the new regulations, we are just doing the floor and painting. Going to be fun fitting plywood around the toilet and so on. Floor had nasty carpet over old wooden floorboards. We are planning on laying vinyl, using plywood to level the floor instead of hardboard. Will be much nicer - and hygienic! :D
Bob
As far as testing goes, use a very low measuring ohm meter, one that will measure 0.01 Ohms.
Expect readings of 0.04
