I just purchased an xpelair dx100hta extraction fan which has a humidistand and timer and need a bit of advice wiring it up.
The old fan was a basic fan which was wired up to the lighting circuits and would come on and switch off with the bath. On removing the fan it has the following connections:
Permanent live connected to yellow from the lighting circuit
Neutral supply in connected to blue from the lighting circuit
There was a third red wire coming in from the lighting circuit but that wasn't connected to anything. (Not sure what this is)
The new fan has the following connections:
L
N
T
The wiring diagram isn't very clear but from what I can gather
I'm guessing that I connect the live and neutral as before?.
I'm not familiar with the T terminal though. Assuming this stands for timer do I just connect the previously unused red wire coming in from the circuit to this terminal?
L
N
T
