Hi, I would appreciate some help with this.
I have a timed bathroom fan, it is in the loft space. Currently it is wired through a double pole isolating switch that is high on the wall outside the bathroom (3amp fuse), all the wires including the permanent live for the timer are on the isolated side of the switch. The switched live is then operated by a pull cord in the bathroom, ordinary one way light switch kind. I've checked in the loft and this is wired like a lightswitch in the junction box up there, ie pulling the cord makes or breaks the switched live to the fan
This is all fine, it works well. the only problem is if your not paying attention it's possible to not know if the pull cord is on or off and this can lead to a bit of trial and error as to whether the fan's on, or on but in it's timed phase which can be a bit annoying with the fan droning on for hours while I eff about with the switch.
All I seem to need is a pull cord switch with a tally lamp so I know whether it's on or off, can anyone tell me if i can get one and can I simply swap the pull cord switch or if it's more complicated than that, ie, does it need a neutral connection to run the lamp as obviously all I have in the bathroom is the switched live.
