Yep another Bathroom Fan related question.
Is it ok if I use a 3A Switched Fused faceplate outside the bathroom instead of a proper 3 pole isolator. Bearing in mind the fan hasn't got a timer so doesn't need a permanent live! With regards to mounting it outside the bathroom can it go at light switch height or does it have to be higher?
Also has anybody in the trade fitted this system before. It looks quite good but would like some other peoples feedback.
http://www.taptilecontrols.com/index.htm
Cheers C
Cheers C
