Bathroom floor tiling
2 Apr 2017
Hiya
I'm planning on tiling my bathroom floor. It is currently lino over plywood (tongue and groove underneath) my plan is to:
Rip up the lino/plywood
Place down some 6mm backboards for the floor with adhesive
Add tape over the joints
Screw down
Tile over
Questions are:
Does this sound right?
What is a good backer board to use? I want good quality but I am on a budget so have been looking at the prowarm ones - can anyone recommend?
I also need to do the walls. Any tips on this would be great. Can you tile straight over the removed tiles depending on what's behind?
Thank you
Having tiled loads of bathroom floors, I would say you're on the right path. Get the Lino and ply up, then go over it all with your bare hands to make sure you havn't missed any nails/screws.
Then coat the floorboards with a SBR primer and allow to dry.
I would only ever use 'Hardi' backer boards - a 6mm notch Trowel with Rapidset adhesive will let you get 2or 3 down at a time, before using Screwfix Turbogold ( the best sharp point ) screws to 'screw as you go'. The boards are marked with the correct spacing for the screws.
Don't buy cheaper boards, is it with saving 2 or 3 quid a board on something you can't fix after its done ?
I've never used the joining tape, just scraped a very thin bit of the aforementioned adhesive over the joins with the back of the trowel.
Re the wall :- that all depends on what you find after taking the tiles off. 9/10 times for us guys it's quicker, cheaper and you get a better surface to work on, to just rip the tiles AND the plasterboard off the wall and re-sheet with new plasterboard.
P.S. A lot of customers later regret NOT putting in underfloor heating mat when they had the chance !
That's really helpful thank you. Ad for the walls, I've just taken off a couple of the tiles to see what's behind and it looks so far to just be plaster and in ok condition. If I smooth it down, will it be ok to tile directly onto or does it need some prep work too?
OP,
A couple of things:
Dont use your bare hands to go over the floor - use the head of your hammer.
Use a knife to cut sealant & paint to free the tile edges - you get a clean line, no spelching.
Go over any paintwork with a belt sander.
Prep & paint the ceilings - attend to any new elec devices in the ceiling or walls etc.
Decide if the floor tiles will go under or up to fixtures - UFH will clear your mind on that point.
If you raise the floor then the benchmark for your FFL is the door threshold.
If the wall plaster is solid plaster then after removing the tile - & belt sanding & priming you can tile on it.
But if you have plasterboard on any wet walls then remove them & use the above Hardi boards.
I use white plastic tile trim for most jobs - no raw or exposed edges.
The mosaics that you've taken off will always look that clean and give you a false sense of "easyness". Take off some more of those larger white ceramics before assessing the state of the wall. Also, if that paint is proper waterproof bathroom paint, and you're tiling above it, then it needs to come off, or at least be sanded and primed as Ree posts above.
Personally, I would take the whole wall off, especially if the intended new tiles are a small size like those originals, as you'll never get them to look flat if you're covering holes.
Different kettle of fish if you're using 300 x 600 or above Porcelain tiles.
Unfortunately it's painted wallpaper so will be taking it off to see what else is happening behind. I've managed to get the bigger tiles off which seem ok but it's just a small segment of the wall so need to see what the rest of the room is doing.
What would you recommend priming with?
