Having lived in my house for a year slowly I am working through the rooms decorating etc. The ensuite is next, there is a light above the shower that I want to replace. At first glance I thought it would be an easy job but having a read around it seems not.
The current light has live and neutrel only and is a class II light I want to replace with a new light which is good for zone 1 (ip44) but is a class I so will require an earth. There is no earth cable in the cable used, do I simply need to find a cable near by with an earth on and spur off that?
The light will be using a 230v feed it is not a 12v light with transformer. Which brings me on to the next question, would I be better fitting a transformer in the loft above the light and having 12v light instead? is that as simple as it is? 230v into transformer, transformer to light?
I am sure people will say get a proper electrician in which is fine as I will probably end up doing that but just want an idea of what will be involved to install this new light.
Just to add I also read any light in zone 1 needs to be protected by a 30ma RCD, looking in the main consumer unit the downstairs sockets and upstairs sockets have a 30ma RCD but not the upstairs or downstairs lighting so I guess this is something else that will need adding?
