I have a problem with our bathroom lighting. It was not switching on properly, so I assumed it was the pull switch, which I replaced. However, I now realize that the problem is that the actual light fitting is shorting against the bulb, replacing the bulb has solved the problem somewhat (it works more often and does not flicker so much). The old bulb has a sort of build up on the connectors, obviously caused by condensation reaching it. Can anyone suggest a bathroom light fitting that would resist condensation entering this part of the fitting? (links if poss). Is it dangerous?
Also, whilst replacing the switch I found what seems to be very old wiring, the earth is just a length of copper sitting between the other wires rather than an enclosed green/yellow that I expected? Does this need replacing?
