Bathroom Lights,Heated mirror and Extractor fan ???
24 Jul 2005
Im in the process of turning my old Bathroom into an En-suite.The House was rewired just after the new colour code came out and has only a existing light in there at the moment
I want to install Extractor fan/light in the shower cubical ,Heated Mirror with built-in shaver socket and 2 down lights
should i
1)Run everything of the existing upstairs lighting Circuit
2)Run a separate feed of the CU for Mirror only
3)Run a seperate feed of the CU for Mirror And Fan
4)Run a seperate feed of the CU for everything and remove the existing wiring for the bathroom light
Its every easy to run a new feed if necessary as the CU is right below the old bathroom
thanks
Even though the installation is newish with regards to colours, that does not mean that it was installed safely. So I would make sure that circuits were safe for continued service and additions/alteration can be made.
As the room is a bathroom are the existing circuits within the room 30mA RCD protected? As they need to be!
Depending on the zones were the proposed work is going to be installed, it may also require building control notification.
With regards to power source, it is possible to have all the new appliances providing the circuit is not overloaded.
Any new circuit would again require building control notification.
For matter of a safety and compliance, it is important the the correct inspections and testing procedures are use prior to commissioning and these are documented on the appropriate forms/schedules/certificates.
As it would seem be your questions, this is not your field of expertise and it would be advisable to get a competent electrician to perform these tasks for you.
Im not sure if i was clear ,the only existing circuit is the original bathroom light which is part of the upstairs light circuit protected by a 6A MCB.
So from your saying apart from i should get a pro in ,everything should be off the RCD side of the CU, So option 4 on my list
Bathroom electrics require 30mA RCD protection, so anything new would require that.
Option 4 is not the only option, you could install a RCBO on the existing circuit or even an RCD protected fused spur.
Ive got a 14 way MEM split load CU with a 80A 30mA RCD with plenty of spare circuits so ill use one of them
thanks
