few questions on bathrooms if anyone can help,
the shower is enclosed by 1 stud wall and 2 external walls, stud wall is fitted with aquapanel, due to the size of the room the 2 external walls cannot be fitted with studs to support this, if its studded the size of the alcove will not accomodate a bath or shower.
the only viable alternative is to dot and dab plasterboard to these walls- plan is to use mr board with advice from a plasterer friend to then skim and seal with bal wp1 or similar.
logic in skimming is apparantly this makes it easier if the tiles are removed later (but aware its not as strong a bond) as it doesnt completely wreck the board.
my questions are:
do you use wp1 before skimming or after?
anyone know of aquapanel that you can dot and dab?
any other suggestions on how to do this (please dont recommend studs as i've already been through this, unless you know of a way to stud it with half inch deep studs!)
thanks all.
my questions are:
thanks all.
