- Joined
- 27 Apr 2003
- Messages
- 2
- Reaction score
- 0
- Country
We had a shower fitted over the bath a couple of months ago, and have been keeping the walls dry using Wilkos decoraters sheet....
I'm about to start tiling and just wondered a few things. Walls are plasterboard with no tiles on them at the moment.
Is it best to coat the walls with a water memebrane? If so, where's the best place to get some?
A lot of people I know have problems with the showers leaking into the room below, and I'm really keen for this not to happen. Is the following going ot be ok, or are there better solutions?
1.Coat the walls with a water membrane (Depending on answer to above question)
2.Seal the bath with sealent
3.Apply a sealent strip between the bath and wall (Before tiling)
4.Tile with the bottom tile going over the top of the sealant strip
5.Seal the bottom tile to the strip with sealant.
Reason I'm thinking step 3 is becasue most water hangs around the bath edge, so if there's sealant there already, and double protection with the strip, any water at the bottom wont get through to the sealant and gradually soak through.
Thanks in advance
Thanks in advance
