Me neither - all's fair in poking fun...mapj1 said:I must wait now to jump on one of B-A-S's postings when he's next tired or in a hurry.. no I don't mind a bit.
Not a word that would have been censored anyway. But I'm not! Schadelijk maybe, at times....I think most people may have noticed that in certain conditions B-A-S= Unruhestifter(I think I might have found a way how to fool the auto censor BTW)
Indeed - cut the channel for the conduit, and the holes for the back boxes so that they lay below the surface, and the conduit can be plastered, or just filled, over. You want the tiler to have a flat surface to work to. The tiler will be able to cut holes in the tiles as he fits them to leave access to the boxes, but when he's gone, make sure that he's not filled the screw lugs with adhesive, and if necessary remove it before it sets.Agree totally with other posters - if the tiles are off, conduit is so much better. You may need to chisel a bit of a groove for it to lie in so it is below the surface properly.
And talking of screw lugs, as the boxes will end up below the surface the standard screws for the accessories might not be long enough, so it might be worth getting some longer ones (M3.5, raised countersunk) just in case.
Oval conduit does not fit well into the round knockouts in boxes, but if you soften the end with a hairdryer you can squash it into a round shape that will go through the holes.
All of those work, but if you've got both ends going through the holes in metal boxes, which are fixed into the wall, and you do a neat job with the channel, you probably won't need anything to hold it in place. I would advise making up some very stiff filler or plaster though, and putting a layer of that into the (wetted) channel before you put the conduit in so that it squeezes into any gaps so that you provide a solid and unmoving base for plastering or filling afterwards.There are many ways to hold it in place while the plaster sets - ..I have seen screws and bag ties, masonry nails at funny angles, blobs of mastic, double sided tape and all sorts of tricks used , and even with the tacky ones, once the plaster has set
