Bathroom
15 Jul 2006
Suffolk
I am setting myself up to fit a new bathroom suite.
Any tips or things I should be thinking of before I get stuck in...
When laying tiles on the floor what thickness plywood should I use
Any help or giuldance would be appreciated
Make sure you understand what sort water system you have, indirect? direct? combi?
You will need to know this when deciding what taps/shower etc you are going for.
You need to be a bit more specific with this sort of question, every bathroom is different. There are so many problems that you can come across if you are not sure what you are doing.
Use atleast 9mm ply for a tiled floor, screw every 100 mm.
