The Mrs is one of those horse types, well she is irish which should explain it!
She has decided to buy a cheap horse "lorry" which will probably be a 1990ish VW LT35 so she can drive it on her car licence. this is great for me as i have a 1990 vw also and i imagine they are mostly the same electronics wise, which will make it easier for me to upgrade for her
Ive always been pretty competent with car electronics as they're pretty easy generally, have made headlight relays and wired up total closures and such in the past.
Now to say the 1990 LT35's are basic would be an understatement, so im already planning a few upgrades to make her life easier, rearview cameras are really cheap these days, and i can fit her LED spotlights and other things that make her life easier.
One thing i would be interested in fitting would be a battery isolation switch, Horse lorrys spend a lot of time not moving, left on yards for trips every other weekend and the battery often goes flat. ive done a split charge relay before when i was into car audio. so im tempted to set her up a leisure battery for the lights and stereo and such. but in order to allow her to start the thing after a long sit at the yard and also for security, id like her to be able to completely isolate the battery.
TL
R
The Isolation switches ive seen online I believe have to be situated between the battery and the rest of the system, and as such have to be situated near the battery am i correct? which would make it difficult to hide in the cab?
is it possible to have a remote isolation switch that could be hooked up to a switch nearer the cab? or would people be worried that it could be switched off while driving.
I was thinking a Relay that was big enough for cranking voltage, if such a thing exists. and a switch to open and close it in the cab.
I suppose in this instance the switch would need to be fused and if the fuse went the power would go out. hmm
any suggestions?
TL
any suggestions?
