Battery powered hand-drill + Safety - Please help!
8 Dec 2007
I know this may be a stupid question, but I am a woman lol.
My outside shed has accumulated about an inch of water in it due to a leak. I want to drill holes in the flooring to let the water drain away. Is it safe to use a re-chargeable battery drill to do this i.e no fear of shocks?
Any help would be appreciated.
Yes you will be fine, but drill it on the slow side so as not to throw water up on your drill and maybe causing it to fail in the future.
bit drastic! what sort of floor is it? can't you bail it out with a dustpan and buckets?
Thanks Libby for your helpful reply. Drilling holes in the floor is the only option I'm afraid - drastic or not! lol Any other opinions on whether this is a safe thing to do are welcome. Thanks to Richard and Freddie for trying to help anyway.
Sorry if I offended you, Freddy but I was only asking for advice about the safety of using the drill, not for other ways of dealing with the water. :roll:
is it a concrete floor, wood or what?
It's not... chipboard, is it?
is it tiled or covered in vinyl or what?
where wil the water go?
It is some sort of board. Not sure if it is chipboard. Would that matter? The water will seep away into the grass.
yes, chipboard absorbs water and then falls apart like wet weetabix if it has been wet. After it has dried again it is as strong as dry weetabix.
so you may be needing a new shed floor before you fall through it.
Shuttering ply is strong and cheap.
Thanks for that information John. I will bear in mind shuttering ply when I have to replace the floor, but in the mean time, I just need to get it drained. Do you agree with libby that it will be safe to use the drill?
John - Thanks for that. That is all I wanted to know. No further replies needed. Thanks to all for their help. :D
