Baxi 105 e leaking diverter pluger seal?
And if the discharge (not overflow) continues to drip then you may need a new PRV or it could just need reseating...
Thanks Ian, I have no space above the boiler, only to the left. The last time I recharged the vessel I did not have the drain point open. May be that was my error? I will try again over the weekend.
Regards
Keith
Hi Ian , thanks, the last time I charged the vessel, I did not open the drain valve, so I will try again, I have looked at other threads and not found info I require, so if I drain off the boiler, leave the tap open , then fit my foot pump to the valve on top of the vessel and pump up to 2 bar, then close the tap , refill the boiler and bleed the air out via the valve on top of the pump?.
Regards
Keith
you do not leave a tap open you leave a drain point open , you need to leave a drain point for the primary water system not any thing to do with taps, then attach your footpump and pressurise to 0.8 Bar do not pump it up to 2 Bar, then close the drain point and add water pressure to 1.5 Bar and you should be good
Thanks Ian, I will have a go this weekend.
Regards
Keith
