Hi all, new here so please be nice
Right I have a Baxi 105e combi apparently after reading many forum posts they are crap to be polite. Am at my wits end with the damn thing so time to ask for help.
The problem started with a lack of hot water none to be precise, after reading many post I decided it must be the diverter valve so I promptly took it out and replaced it with another (also replaced pressure guage as the capillary pipe snapped off when i opened the front panel...grrrr). Still no hot water, checked yet more posts and decided it must be the heat exchanger, removed this and gave a damn good clean replaced and bobs your uncle as much piping hot water as i need. Job done i thought...... nope...... the pressure when the central heating in is on started going off the scale. Decided this could be caused if there was anh holes etc in the heat exchanger that were perhaps previously blocked by the crud I washed out, so ordered a new one just fitted it and still have same problem.
Have bled and bled the rads several times to no avail. I have noticed that all the rads downstairs seem to heat up from the top down over and do not get particularly hot at all whereas the rads upstairs are piping. There only seems to be a slight trickle of water coming from the prv where i would have expected a lot more as the pressure is off the scale therefore well over 4.5 bar, the pressure also goes up when the hot water is turned on, should this happen? I did also check the expansion vessel the other day which was just under 0.5 bar so topped up but still no joy.
Has anyone got any idea what could be causing my misery? If so please could you let me know as I really need my heating.
Thanks in advance,
Pete
Thanks in advance,
Pete
