BAXI 105e Instant Combi - DHW Cutting Out, CH OK
Discussion in 'Plumbing and Central Heating' started by lejonnieboy, 22 Apr 2015.
  1. lejonnieboy
    lejonnieboy
    22 Apr 2015
    2
    Thanks Received:
    Cambridgeshire
    Country:
    I have a problem with the hot water on my 105e Instant Combi.
    When I turn a hot water tap on, the boiler fires up and hot water flows, but not as hot as normal (I can easily keep my hand under it). If I watch the temperature LEDs, they climb to maximum and then the boiler cuts out with the flame and safety thermostat LEDs flashing - this takes around 20-30 seconds.
    I can reset it and repeat.
    Central heating works fine - temperature LEDs look good and no cut-out.
    So it seems like the boiler thinks the hot water is hotter than it actually is.
    I've checked the hot water thermistor resistance (at the PCB connector end after disconnecting) - it's 16 kohm with cold water running through and drops to 3-6 kohm when the water is hot. This seems reasonable. The manual says 11 kohm when cold so although there's a difference I suspect the thermistor is OK (if it was faulty a higher resistance would mean the boiler detects a colder-than-actual temperature).
    For good measure I checked the safety thermostat and that is OK (close to 0 ohm). And anyway, if it was faulty I presume the CH would not work?
    Any ideas? My best guess is a PCB problem but as that is quite expensive I thought I'd just check with those more knowledgeable than me!
    Thanks in advance!
  2. ollski
    ollski
    8 Oct 2003
    7,092
    Thanks Received:
    544
    Bristol
    Country:
    Is the hot water going to the radiators?, probably be looking at a diverter valve to begin with.
    • Thanks Thanks x 1
  3. Sponsored Links
  4. muggles
    muggles
    28 Oct 2005
    13,431
    Thanks Received:
    3,104
    Daventry
    Country:
    Unlikely to be the PCB. I'd say either diverter or blocked plate heat exchanger
    • Thanks Thanks x 1
  5. lejonnieboy
    lejonnieboy
    22 Apr 2015
    2
    Thanks Received:
    Cambridgeshire
    Country:
    Thanks! I'll do a bit more investigating...
  6. DIYnot Local
    3 Sep 2019
    Country:
  7. Sponsored Links
Loading...
Share This Page
