Baxi 105e leak query
4 Oct 2005
Essex
Yes I know, this has been done to death, but I refer to ://www.diynot.com/forums/viewtopic.php?t=24971&start=0&postdays=0&postorder=asc&highlight=
specifically Corgigazza's reply/fix:
turn off water, remove nut gland seal, place small rubber o ring over shaft,
smear gland & push rod with silicon grease, replace nut, good as new worked on loads of them so far no call backs.
how simple is this?
Can I do it myself or do I need..(Edited because it offended Bamber gaspipe's delicate sensibilities!)..a plumber?
Just a question - what is the nut gland? I have replaced a 3 valve diverter in my time and installed a few things as a DIY, but never come across this term!
tollanarama said:
Can I do it myself or do I need..(shudder)..a plumber?
It might be wise on your part to leave the smart Alec comments until your question has been answerer by a plumber/engineer.
If you have managed to change a diverter valve then I would have thought you could manage a "nut gland".
I do have to wonder what is the problem that causes so many people to have to say things like """do I need..(shudder)..a plumber""".
A plumber should be a polite helpful person who comes quickly when anyone has a problem and fixes the failure at a reasonable cost.
A plumber's charge for a small job probably averages £40-£90. How do you respond to a Solicitor who starts his bills at £300 and more often charges £1000-£8000 if you have anything more complicated.
That price does not include any boilers or radiators or bought in items with any cost. He usually charges £60 for postage and telephone calls even though he never calls you himself and the stamps come to less than £2.
Tony
There is not enough humour on this site for me, but blundering onto a plumbing/Heating forum & insulting the very people you are seeking advice from is not very wise...in fact I`m off onto the `Electrics`part of the Forum because I`m re-wiring my house..I`ll ask one of the `Sparks`on there how to do it....then I`ll inform him how I don`t want a `spark`doing the job (shudder) when I can obtain all the info from him..Let`s see if he thinks it`s humorous...
Wow, I'm amazed at the hostility on this forum.
Here I am, an ordinary Joe trying to fix a small problem!
Agile - I would like that too, but it's a fact of life that all plumbers aren't like that! My old next door neighbour was a plumber and he was the biggest rip-off merchant around; he'd screw his own mother's nut gland if he thought he'd make a quick buck! He once replaced every part in a boiler, apart from the part that was actually defective, before the poor person called in another plumber to fix his bodge work.
You'll probably get a laugh - all the sparky's I know are great guys!
I thought the point of forums like this is to share knowledge & help others - if I can fix the problem myself I don't see why I should worry a plumber (and save some money in the bargain!)
Getting back on subject - I asked a reasonabe question interjected with humour and was hoping for a civil reply!
Anyone willing to give me a civil reply to my question?
I thought my advice was "civil" and would have been helpful?
Repeated advice:-
Tony
You will not receive any further reply from myself...Agile has given you a most civil & as far as I am concerned `generous` reply.
Repeated advice:-
Tony
Yeah, sorry Agile, your advice was fine! - I was fired up by Bamber gaspipe's comments.
I'm not a plumber trade - far from it (but if you ever need to be stitched together after an accident - see me!) and I have replaced a diverter valve with the help of members of this forum like yourself who was only too eager to help.
My query is, before I go blindly plowing into my boiler, I want to be really, really sure that I know what part the nut gland is!
Is it the small nut on the end of the push rod that comes out of the Diverter valve Assembly?
The simple answer is that I have not ploughed through in search of that term.
Most joints in a boiler with a nut could be described as "Nut Gland". I would not blink if someone called a diverter valve connection a nut gland.
Before you perform any operation on your boiler you have to determine what the problem is and whats causing it. If its something leaking with a nut then the best thing is to loosen the nut about 30 degrees and then tighten it about 60 degrees or until it a bit tighter that it was when you started.
Tony
Thanks for you reply - I'll take a look this evening - although I'll probably have to get a plumber out!
Anyone have the number of a reputable plumber in Southend on Sea, Essex area??
Could try pete the plumber, The last i heard he was working on southend pier last October
