hi, got a strange problem with a baxi 105e, on initial startup on either central heating or dhw, the pump/low pressure light flashes after a few seconds.
the pump prover pin is not extending into the microswitch. when I take the front nut off of the pump, water flows out and then the pin comes out and activates the microswitch and the boiler fires. put the nut back in and all works ok until it gets to temp and switches off, then it follows through the same again. it only seems to run for about 3 minutes and it gets up to temperature very quickly. pump is spinning ok, the only other thing I can think is partially blocked heat exchanger with a weak pump. does anyone have any suggestions??
thankyou in advance.
