Im sick of the site of these ive got 3 on the go can anybody help;
House 1
2 Bedroom with 5 rads 3 upstairs work, 2 downstairs wont get hot. Ive tried turning upstairs off and no luck, ive flushed the downstairs rads with mains pressure and put mains pressure through the downstairs rads pipework which flowed ok ( i did get dirty water through the rads and pipework mainly sludgedy colour and also orangy iron colour).
The boiler is downstairs in a make shift bedroom it has grey plastic 15mm pipework from the boiler for the domestics and the flow and return. The hot water works fine, ive also cleaned the main heat exchanger with Fernox DS3 and flushed cold mains through the boiler. Any help appreciated im still stuck with no heat to downstairs.
House 2
No hot water, b4 i arrived its had a new pump fitted and a dhw diaphgragm. Customer says can get hw with heating on. I investigated and found pump light flashing but heat was working on arrival. Then it started working ok. Checked DHW heat exchanger and cleaned with DS3 and removed some shale, put it altogether and added some chemical into AAV on pump. Tried it again and central heating flow switch wouldnt lift tool it apart again checked diaphragm seemed ok put it back together and starting working again BUT ivce still got the same problem no Hot Water. Any ideas ive said i would pop back when ive got more time, Its in a Hard Water area and the water in the system doesnt look to clever. Any help appreciated has any found an area where these boilers normally blockup.
House 3
Same as house 1 downstairs heating not working, its had a pump head on and piped in ****ty plastic pipe.
Im a bit peeved off with these boilers at the minute as you can imagine, any help would be nice, i couldnt contact Baxi as it was after 5pm when ive looked at them.
House 1
House 2
House 3
