Baxi Advice
As @picasso said, the boiler pressure has no bearing on the hot water side, other than, it needs the pressure for it to work. The pressure you're referring to is the heating side, but required for the boiler to fire up for hot water.
This sort of issue i would assume that the British Gas engineer could resolve/find out if they were called out right? The problem here is i have had them out a couple of times now and they are saying that the problem is with the boiler.
Is there any way that i can test or make lots of tests and document to show them what is happening? If it is the venturi then that should means its a boiler issue and not the piping? As i said before it was working fine until recently
Just an update on this one, had the boiler man out again after he phoned me up regarding a hive install on the off chance. I told him about the venturi and he said yeah ill change that out, he got it out (it was destroyed) and now everything is working as it should again.
Many thanks
