Baxi Bermuda 401 Problem
15 Sep 2010
Cumbria
Hi i am having a problem with my baxi 401 when i turn the main switch on in the bedroom the 3amp fuse in it keeps blowing i thought it might be the pump but it is only 12months old other than that i have no idea any help would be much appreciated.[/b]
system ?
just because the pump is 12 month old don't mean jack
disconnect it first
could be zone valves
could be gas valve
could be a mouse has chewed the wiring :?
could be anything. a compotent person should be able diagnose it. an a electrician would be first port of call. but probably in the end it will be a plumber thats called in to do the work.
Nah, call a plumber / heating engineer first. Should diagnose within 15 mins max
A competent heating engineer will be able to deal with any heating system faults.
Usually the pump. They can fail after one day or 20 years!
If its blowing a fuse straight away when the fused spur switch is turned on with clock in the off position then your first port of call is the motorised valve .
Check around it for little water leak dripping into it (pump valve spindle the usual culprit) occasionally its a leak within the valve/
could be pump but most common is melted flex or cable where it runs too close to the burner and has gone crispy and shorted or just melted through.
