Hi to all, we have a Baxi Bermuda back boiler that has a mind of its own. If I turn the room thermostat right down the boiler will heat the water in the tank exactly as the timer is set and to the temp set on the stat, as soon as you turn up the room thermostat it all goes wrong, the boiler fires and heats the rads and stops when the temperature is reached but then continues to fire up and heat the water in the tank regardless of the setting on the tank stat. The only way to stop this is to turn the tank stat up to max and it then will temporally stop heating the water, if you turn off the timer the heating stops working but the boiler keeps heating the hot water. The only way to stop this process is to switch the whole system off!! We had the room refurbished some time ago, is it possible the programmer has been wired up wrong? Please help this is driving us mad (and costing a fortune in water heating).
Mike
Mike
