Baxi Boiler Diaphragm not working
20 May 2010
Cardiff
Hi Everyone, I have the same problem as per this thread: http://www.diynot.com/forums/viewtopic.php?t=94199
Basically the pin won't come out when the hot water is turned on, however, if I pull it out with a pliers (while the water is on) it will stay out and go back in when the water is turned off - but will not come out itself when the water is turned on.
Can I try greasing it with oil? (If so which oil - will olive oil do?) Or do I need to install a new diaphragm? Are they difficult to install?
Thanks in advance for any help.
Most probably diaphragm, I doubt oiling the spindle will help, a clean and greas when it's out will help
Not difficult at all.
Isolate electrics
isolate cold mains into boiler and leave hot tap open
remove screw and remove microswitch infront of pin that pops out
remove 2 no thin pipes at top of diaphram housing
remove the screws (5 or 6?) from front face of housing
remove front plate off housing which gives access to diaphragm
replace in reverse order. Be careful with any water still in the housing so you dont get the electrics wet.
Many boiler parts use rubber seals and these can be damaged by ordinary oil.
Silicone grease is the only thing to use for lubricate moving pins etc.
Tony
Tony
Tony
Hello again, I just got around to remove it and clean and grease the pin(/push rod) - and although it worked the first time, it has stopped working again.
Do I need to clean or grease anything else? Or should I just order a new one? (Or could something else be the problem?)
Thanks for any help.
Just change the bleeping diaphragm. It has probably stretched or has a hole in it. Better still get someone in, it's a 15 minute job.
