Hi Guys
As usual im sniffing for some help.
Been and serviced a boiler, burner insulation in a bad way and defo needs replacing, the only info i have is from the boiler casing which is that it is a Baxi 38m 3RS.
Now can i use any insultion or must it be specific?
If it helps this boiler is nearly identical to the old solo with the exception that you can get to the Heat Exchanger by undoing four wing nuts above the burner wing nuts.
Bottom casing clips off and only two front facing screws hold rest of case on.
Any ideas would be gratefully recevied and if not which boiler holds the largest back peice of burner housing insullation?
Charles
Charles
