Baxi Boiler - Water gets hot then cold then hot.
17 Aug 2011
Birmingham
I had a problem with my boiler (Baxi Duo-Tec Combi 40 HE A). It was overheating and then when cool loosing pressure and stopping. I called the guy that installed it and he diagnosed replacing the pressure vessel. This he did, (but at a huge cost – I checked the cost of the part and worked out he charged me a little over £170 per hour to fit). However the fix sorted the problem.
The thing is that since he left the hot water runs alternately hot and cold. A bath full will be just warm.
Can anyone hazard a guess what is causing this and is this something that I can fix myself rather than spend the kids Christmas presents on getting him in again?
Thanks.
It's difficult without looking at the boiler but sounds like it could be a partially blocked plate heat exchanger. This type of blockage will cause the boiler to get up to temperature too quickly which will cut out the burner until it cools and will then fire up again. This causes the water to come out at inconsistent temperatures, hot, lukewarm, hot, lukewarm, etc, etc.
It's not a boiler I'm familiar with but there's plenty of guys on here that do and might think it's something else.
Yeah, agree with above or DHW thermistor. How long has the boiler been fitted ? Was it flushed ?
The boiler is about six years old. It was fitted when we bought the house and enlarged the existing CH system. I am not sure what flushing entails or whether it was done at the time we fitted the boiler.
A fixed price repair would have been far cheaper for future reference! Either from Baxi themselves or another company. Extremely unlikely that a 6yr old expansion vessel would need replacing. Simply pumping it up usually sorts it for several years at a time.
Read the instructions in the manual on how to replace dhw plate heat exchanger. Once you have the the plate removed put in a bucket with boiler water and some citric acid power from your local chemist. Leave i half hour then run it under cold water. Re install and you should be fixed.
Brilliant advice, I'm sure nothing can go wrong there with a DIY'er taking major components out of his boiler! :roll:
Draining a boiler and taking two screws out is hardly major! As for getting charged £170 per hour maybe thats your problem! This site is for advice. If he feels comfortable doing it. Its not rocket science
Thanks for taking the time mate.
I checked in the manual. First instruction "Remove gas valve as described in section ..."
Square one!
Sorry i apologise. I didnt realise you were the person looking advice. I thougth it was someone having a go. You should be able to remove the plate without touching the gas valve. Have a look. I cant remember ever having to remove a gas valve to remove a plate. Tho cant remember ever cleaning a duo tec. Its usually just two alan key nuts .
No problem. Honest mistake.
Thanks for this I'll take a look. Unfortunetely the in laws are up for the weekend and her dad is mustard keen but much better at DIY in his head than in reality. I'll get to it on monday and let you know what I can find.
Thanks again.
