Looking to change my boiler. Want a heat only one been offered a Baxi as it's rear access. I've read this has an aluminium heat exchanger. Any one have any views on these boilers?
Good enough boiler, but I think main make the exact same boiler but quite a bit cheaper @gas112 is the man to advise you better, I have tagged him for you so hopefully he will be along soon to give you some more advice
Personally not a fan. If you need a rear flue then you'll have to put up with an Ali heat exchanger I think, but I'd take a Vaillant over a Baxi. If you've got space for a top flue the Viessmann 100 is a good option
