Can any of you help?
I have a Baxi solo WM 30/4 Boiler.
Whenever i turn on the central heating or hot water, after 5 - 10 seconds the RCD trips out in my main consumer unit.
The pilot light still stays alight at all times but does not kick in when the central heating or hot water is switched on, it just trips the RCD.
I have checked the wiring from the thermostat control to the boiler and the connections in the boiler and all seems ok.
I did have some trouble with the 3 way change over the other day, when i had the central heating on i switched on the hot water and the central heating became twice as hot and no hot water, i manually reset the change over (by pulling the lever on the side) and this seemed to cure it for a week and now the RCD trips.
Could these be related?
If not can any of you give me any ideas
Many thanks in advance
Michael
Michael
