Baxi Combi 130 HE
19 Nov 2009
Sussex
I have a Baxi Combi 130 HE . When the CH is on demand it goes through the ignition cycle, ignites and then cuts out after about 3 seconds. It will then re-try after about 3 mins. and the whole process starts again. Sometimes it will ignite and run properly, other times it fails all together. DHW is fine and I have no fault indicators. I have tested the thermistors and boiler stat and they are fine. Could this be the actuator valve and if so, is it expensive to replace.
Trvs all off or more than likely return (and/or flow) filter blocked
