Hi, i am after some help please with my Baxi Combi 133HE plus.
I inherited this boiler when i moved into my house. Over the winter the pressure gradually dropped to under 1. I got an engineer out to service the boiler. He did some tests and topped up the pressure and said everything is fine.
The pressure has dropped to under 1 again. I have had a look at topping the pressure up myself. All of the pictures or diagrams i have seen have shown two taps that need to be opened when attached to the filling loop. On my boiler i do not have any of the plastic taps. The connectors are brass. Also my filling loop is attached to my boiler but from what i have read this should not be permanently attached - the engineer did not highlight this as a problem.
I can take a picture if it helps to show you what i mean.
