Baxi Combi 80E leaking water
17 Nov 2011
London
My Baxi boiler is leaking small amounts of water (dripping), it seems to be leaking through the pushrod hole on the DHW pressure differential value. I have included a pic and page from the manual of the boiler. Is likely that the diaphragm needs replacing or something else to stop the leaking water?
Any suggestions as to what is causing the leaking of water?
Thanks in advance guys :)
Yes diaphragm, pin and nut usually come as a kit.
Your local plumbers merchant should be able to supply one.
Usually straight off the shelf as it is a common boiler.
Na he will get the board change when the water goes into it :wink:
