I have had reason to look up the range of temperature for mains water supply in the London area.
"Mains water is distributed across London through a network of pipes, and varies in temperature between 5 and 20°C during the year."
That led to some thoughts about boilers.
With primary flow set for 60°C the delta T varies from 55°C ( in winter ) down to 40° ( in summer )
Delta T varies from 38°C ( winter ) and 23°C ( summer )
It would seem sensible that the flow restrictor in the boiler should allow enough flow for the 23°C delta to be achieved before the modulation reaches its bottom limit and rapid cycling has to happen.
domestic hot water thermostat set to 43 °C
